Results 1 to 10 of 13
Thread: 380 Upper Manifolds to suit Magna's (with 380 motors)
Threaded View
    Default 380 Upper Manifolds to suit Magna's (with 380 motors)
    We are now doing these for people running the 3.8 motors in their Magna's and Verada's
    We have done a couple for testing thus far, responses are there is a slight drop off bottom end initially however off idle you start to feel the difference and also allows the motor to produce good power higher up through the rev range where the standard 6G74 manifold lacks.
    They are a direct bolt on, you use your existing throttle cable, your existing air intake and you get supplied all bolts required plus the 2 rear brackets for the support. You use your existing throttle body.
    These do NOT have EGR so running this is entirely at the risk of the person driving the car as far as EPA goes.
    **Pricing is $275 for this as an outright purchase, no need to give us back your old standard manifold.
    **We can arrange fitting (duh!)
    **If you have TCL an extra fitting is required which is $10.00 additional
    **You will require the 380 rear rocker cover (I dont like bending pipes out of the way), most motors we have supplied or fitted will already have the 380 rear rocker cover anyway.
    To save messy posts everywhere, PM's we dont see etc anyone interested please call us or email us as per our banner below or sales@mitsfix.com
There are currently 3 users browsing this thread. (0 members and 3 guests)
